I just got my BIC Venturi's today
christhemac said:
I was all set to buy the Athena ASB1 Speakers and Home Theatre Center Speaker Package (ASB1, ASC1, ASR1)...but they dont deliver to the States. I was bummed b/c I was looking forward to hearing the bipole speakers.
So I regrouped and went to plan B: 4x DV62si and DC62CLR-S.
BUT...then I discovered the DV-26 on the web...not a bi/dipole but seems to be designed as a rear surr. speaker. Now I am thinking of using these for rear surrounds instead of a pair of DV62si's.
However, I cannot seem to find a whole lot about them (ex., tweeter and woofer materials). Here's what I know:
Power handling: 150 watts
One woofer and two 2" tweeters
2-way, tuned vent bookshelf speakers
Mirror image design
90 dB sensitivity
3kHz crossover frequency
Frequency response: 49Hz-20kHz
Black laminate finish
15" W x 9 1/2" H x 9" D
7 year limited warranty parts and labor
This seems like it would match up nicely with the DV62si speakers.
Any thoughts or ideas? Do you see any issues with the 2 inch "tweeters".
Thanks.
I just received my BIC Venturi speakers today. I decided to go for floorstanders up front, so I went with the DV84's. I got the DV62CLR-S for the center (it is the only speaker that has not yet arrived). I was originally considering the DV62si's for the surround speakers, but I went with the D-26's instead, for probably the same reason that you are considering - they seemed like they would spread the sound better based on the dual-tweeter configuration. I also got the V1220 sub.
Since I haven't ordered the rest of this system yet (I am still trying to make a decision on the AVR), I tested the speakers with an old Kenwood receiver that I got years ago (about 8, I think), used from a buddy. Since the receiver doesn't support surround sound or a subwoofer, I only got to test the DV84's and D-26's in A/B stereo mode. I had an old pair of Infinity Reference E-L bookshelves, which I also hooked up, for comparison purposes.
The DV84's sound great. Now, I have heard from others that out-of-the-box, all of the BICs may sound a little muddy, and that the sound should improve over time as the speakers burn-in. If that is true, then these are going to be really great. With frequency response from 27Hz to 20kHz, I knew they would provide plenty of bass, but I was very pleasantly surprised by the clarity of the highs. They have a full, rich sound, and at the same time sound clean and crisp, with good separation. I played Pink Floyd, Donald Fagan, The Rippingtons, Dire Straits (live) and James Taylor, and they performed well across the board. Being floorstanders, they obviously sounded much fuller and richer than the Infinity bookshelves.
Unfortunately, the D-26's were another story. Maybe the burn-in period is a bigger deal with these, because I didn't think they sounded anywhere near as good as the DV84's. I expected less bass, but I didn't expect the lack of clarity. These speakers had less separation than either the Infinity bookshelves or the DV84's. Now, to be fair, these speakers were only about $100 for the pair, but I was hoping for better sound. I am going to give them a little while to see if they sound better, but I am now seriously considering sending them back, and going with either the DV62si's or even the DV52si's for the surrounds.
At this point, since the drivers for the DV62's are more like those on the DV84's, I would recommend getting four of those over two of those and two of the D-26's. Like I said above, maybe they just need to burn-in, and I'll feel differently later, but at this point, I probably wouldn't recommend them.
Good luck with your decision.
