Help!! My Denon Avr-2802 Won't Play
U
Unregistered
Guest
When I turn it on, the power supply indicator LED flashes fast and the display is off. It seems that it has to do with "Protector circuit". What can I do to make it work again?
WildCelt
WildCelt
Check your owners manual for the right button combo. You have to hold two buttons while plugging in the receiver.
I am having the same problem with my 4802, and unfortunately re-initializing the microprocessor didn't work for me. Hopefully it will for you.
