stizach
I have an onkyo 702 receiver connected via multichannel input to a denon dvd-2900, for sacd and dvd-audio playback but I need another multi-channel input for the upcoming hd players, any suggestions?
stizach said:I have an onkyo 702 receiver connected via multichannel input to a denon dvd-2900, for sacd and dvd-audio playback but I need another multi-channel input for the upcoming hd players, any suggestions?
Don't worry too much before you are ready to buy a new player that requires another input. Until you have a problem, don't try to fix it, because no matter what you try now, it may turn out that the new thing, once obtained, will make a different solution better than what you select now. Then you may decide you want a new receiver that can decode the new audio formats for the new players, or you may just buy a switch box that allows you to switch between different inputs. If such a product is needed, someone will make one when it is needed. And if not, you could always use multiple two channel switch boxes, which would be inconvenient, but would work. Just wait until you have the problem before you try to solve it, as appropriate solutions are more likely to present themselves at that time.stizach said:I have an onkyo 702 receiver connected via multichannel input to a denon dvd-2900, for sacd and dvd-audio playback but I need another multi-channel input for the upcoming hd players, any suggestions?
