help me decide the rating of amp
K
kalakotim
Good morning Everyone!!,
I am a newbie in HT field, so pardon my ignorance. I have PSB T45s as fronts( L & R) connected to Denon 1905.I am thinking of buying a two channel amp to drive my fronts.The speakers are rated from 20W to 150W and Denon is rated at 80wpc. Can i go for a 200w/channel amp?. Then would it blow off my fronts? or is there a way to control the gain on the amp?
Thanks
crashguy
crashguy
A 200w per channel amp would be fine. You are far more likely to kill a speaker with a clipped signal (overdriving an under powered amp) than you are from overdriving them with clean power. The wattage ratings on speakers are notoriously meaningless. I remember a test of psb stratus golds in stereo review about ten years ago where they took almost 10,000w without damage.
Good luck on your amp search.
rschleicher
I agree with just about everything in the previous post, but did want to nit-pick a little about the 10,000 watt test by Stereo Review. As part of his normal testing process, Julian Hirsch (who use to be the main tester/reviewer for Stereo Review) would apply single-cycle tone bursts at various frequencies, to see how much power it would take to literally bottom-out the speaker drivers. As the previous poster noted, this was often in the many hundreds, or even thousands of Watts. But, only for one cycle (so with a 1 kHz tone burst, the total duration was only 1 millisecond). You could not apply nearly so much power of a continuous tone, without causing damage to the speaker.
But, the main point of the post is totally true - it is far more likely to damage a speaker by driving it with an underpowered amp, driven to clipping, than via too much clean power.
Thanks
Why are you thinking of this upgrade?
You would gain about 4dB of volume, not that much.
crashguy
crashguy
Exaggeration for effect....
K
kalakotim
I wannna take load off the receiver .. its rated 80WPC when driving 8 ohm speakers.But mine are rated at 6 ohms
K
kalakotim
Thank you all.
