Help me Custom Installers: TDQ-150 remote codes!
adk highlander
adk highlander
Sith Lord
A little help from the custom installers out there would be much appreciated.
I have a Parasound TDQ-150 tuner that I got second hand without a remote. I was able to get most of the codes with my harmony 880 but it did not include the "memory" code for setting the presets.
I have searched remote central and others but they don't seem to list this code. I would love to get it in a hex code or an mxf file if possible.
Thanks!
N
nheuer
Parasound TDQ-150 Remote (Hex) Codes
Hello
Do you by any chance still have the Hex codes for the Parasound TDQ-150 Tuner?
Thanks
Nick
adk highlander
adk highlander
Sith Lord
I do still have what Scott was nice enought to share with me. I have CCF file that I was able to bring into the universal browser with my URC remote.
What remote do you have?
N
nheuer
TDQ-150 Hex
Actually I am using a NuVo Concerto zoned audio system. So all I really need is the hex codes if you have them. I can manually load them in thru the configurator software.
Thanks
Nick
adk highlander
adk highlander
Sith Lord
Sorry I don't have the raw hex codes. I can see if I can export them tonight from the URC software. Can you import any other file types?
N
nheuer
Hex Codes
I am not sure, the software for the system is pretty limited and when I talked to Tec support at nuvo they only reffered to hex. But if you send me what you have I can play around with it as well.
Thanks for all the help.
Nick
N
nheuer
hex
Hello
It looks like if I can get the CCF file I can bring up the hex codes for cutting in pasting in Pronto edit
david1
I need the code as well, there is a file at Remote central but is isn't 100%.
I need the file with the 1-9 buttons. Anyone have ?
I can take hex or CCF, going to pronto neo , I will share once I get it ?
Thanks
David
bandphan
bandphan
Thanks
David
If you want I can send it tomorrow.
