Help me choose the correct 7.1 speaker!
briansmith
<font color='#000000'>Help me choose the correct 7.1 speaker!
MY SETUP:
I currently have the following:
MA GR-60s for front Left and right
MA Gold center for center channel
MA GR-10 bookshelves for rears.
MY LISTENING:
I want to upgrade to 6.1 or 7.1. My receiver has Dolby Pro Logic II for 7.1 which I would like to take advantage of. My listening is 75% music and 25% movies.
CURRENT SPEAKER POSITION:
I have my rears set up directly to the side currently. The center rear channel will go right behind my couch on a coffee table that is up against the back of the couch. There is a big opening behind the couch so I can't mount the speaker on the wall.
QUESTION:
I would like to purchase one speaker for the center rear channel is possible (for budget and aesthetics reasons). I can, however, go to a pair if it will sound better.
Since I listen mostly to music what would you recommend? A single GRFX ( http://www.monitoraudiousa.com/products/gold/index.html ) for the rear, a single GR-10 bookshelf, or another Gold Center channel? Keep in mind that the speaker will only be 1-2 feet from my head.
What would you guys recommend? Should I get a single speaker for the back or a pair? Center channel, bookshelves, or bi-pole?
Thanks in advance!
-Brian</font>
