There are two more items you will need in addition to the thermisters.  You will need two
circuit boards, for a total of $28.
You will need two
terminal cups, for a total of $11.40.
The Thermisters I can come to a close approximation.  The thermister in addition to providing tweeter protection is also padding the tweeter.  The spec is 12 Volt, 21 watt, which means the thermister has a resisitance of 6.8 ohm.  The closest I can come is two 10 ohm thermisters in parallel which would be 12 volt, 18 watt.  That difference is only a fraction of a db, so will be quite satisfactory.  So you will need four of these
thermisters sourced from Mouser for a total of $3.72.  I struck out with digi-key.
So your total for electronic parts will come to $114.52.  So I was pretty close at $100 off the top of my head.
Now when you build your enclosure, use at least 3/4 mdf or cabinet grade ply wood.  You will need to brace well, or it will ring like a barrel.  Vertical and horizontal internal braces need placing every nine inches.  You need to cover 50% of the internal surfaces with Rockwool (mineral wool).  Make sure you cover all the back surface behind the driver with Rockwool.  Apply the balance to top, sides and bottom towards the front. to prevent reflections from the driver cone.
Swerd thanks for helping with the heavy lifting.
