Help : Klipsch SW-112 and Bic PL-200
Short Man
Good day,
I am currently looking at setting up a home theatre system. I am looking for a sub around the $300 range. Unfortunately I do not live in the US and therefore cannot go to any stores to hear the subs for myself. I have to rely on reviews on forums such as this.
I want to use the system for both music as well as Movies. The room the sub will be going in is around 300 - 350 sq ft but it opens up into a hall way which leads to a 12 x 12 room. I wanted to know of the two subs mentioned which would you guys consider to be the better sub, meaning which plays louder, deeper and cleaner.
Right now I have tv speakers and a Sony Shake 33 (The bass on this sounds like CRAP). So basically any of the two subs would be a HUGE step up for me.
Thanks.
shadyJ
Speaker of the House
Staff member
I wouldn't think there is a huge difference between the two, so I wouldn't sweat this decision too much. Same cabinet dimensions, similar tuning points, similar amplification power. They are going to behave roughly the same.
Short Man
That's good to know then. Thank you for the response.
