Help...Is this worth it ... Monster Cable THX 200 Series Speaker Set?
andersonaudio
I have been reserching around for the best home theater system, sound, looks, make,etc. I have found a Monster Cable THX Certified 200 Series set. It's really expensive, it looks great, read many reviews on it. Should I buy it or is there anything else out there better? Any personal experiences with this set?If I did decide to buy it can I get by with just 2 floor towers, 1 Center, and 1 Subwoofer? Or do I need the full 7 speakers? What is the best THX Certified AV receiver to power this system? Thanks.
Monster are not known as a speaker manufacturer, of any repute. They are known for filing mean spirited lawsuits, that try to put hard working business owners out of business.
Yes, you can do better. Look at specialist speaker manufacturers. We need a budget.
Monster makes speakers...?!?! :eek:
About as much as they make remote controls- no, they have them made for them and if I know them, they'll be filing all kinds of lawsuits claiming that they invented the technology used in all loudspeaker designs, even the ones from the 1920s.
BMXTRIX
BMXTRIX
You will find out here quickly that Monster is not well regarded due, in large part, to very anti-competitive lawsuits and extremely overpriced product.
Much like Bose, the speakers you are looking at aren't something you should ever consider if you do five seconds of actual research and do NOT read the hype reviews, but get into the actual specifications of the product.
That said, I've found that while Monster has a lot of poor business practices, and does overcharge by a wide margin, their product typically performs very well.
The big downside here is that you would be extremely foolish to buy anything from them.
I mean, yes, their stuff sounds good, but if you want something that sounds good, and there is a ton of stuff at half (or less) the cost, then why would you waste your money for any reason OTHER than that silly brand name?
Come up with a realistic budget, describe your room, then ask for some actual options. I suggest you go into local A/V stores, especially if you can find some smaller specialty stores, in your area and actually listen to different speakers. It may be worth it to try an Axiom or Aperion set of speakers in your home as well.
Also, a good subwoofer is often a best value when you buy from a subwoofer manufacturer instead of from a speaker manufacturer. There are many possible recommendations depending on your budget.
But, it looks like this is what you were referencing in your original post:
http://www.amazon.com/Monster-THX-SL200-TWR-BK-Certified/dp/B000CC5PVA/ref=sr_1_2?ie=UTF8&s=electronics&qid=1299343135&sr=1-2
and at $900 (is that for one or two speakers?) you have enough budget to end up with a speaker setup that is a fair bit better.
http://www.monstercable.com/lit/MANUL_THX_G1ls.pdf
There is nothing in here that indicates they are anything special.
It also appears, from their complete lack of direct marketing on their website, that these speakers are no longer in production, and may be discontinued. (???) - Not sure on that, but it's extremely unusual for Monster to not have their product listed up front and center.
I would just avoid them and go to a serious speaker manufacturer. It's a much safer and cost effective approach to things.
PearlcorderS701
Wow...I didn't even aware this was available...:eek:
But, as stated, this is most likely made for them by a third party presence...
Anyone know how good these speakers are? Not interested in buying, just curious...
If someone had to guess, who's making these for Monster? The design looks familiar...
jamie2112
I didn't even read any posts all I can say is NO....
