Summary: Need advice on sonically insulating/isolating speakers in a wall unit.
I am in the process of finishing an A/V installation in a great room adjacent to our kitchen. The site is far from ideal but it is where the family spends much of our time so I have to make do. I have a space in the basement that will ultimately become a dedicated theater but that is out in the future. Importantly, wife approval factor is also very important.
We have designed and installed a built-in “entertainment center”.
Fortunately, I had a great deal of influence in the design and sizing of the unit (see photos attached). The LCR and sub will be located in the spaces covered with grille cloth (yes, I am fully aware of all the compromises this entails, especially the sub’s placement) Given the dimensions of the RPTV and the equipment stack, I was not able to dimension the speaker holes to the dimensions of the speakers. Thus, as you see, there is much dead air around the sub and the mains. The sub space is also open in the back the center portion of the wall unit (i.e. behind TV, etc.)
I am no acoustics specialist but I have read enough to believe that I should consider filling that dead space behind and around the speakers with insulating material. I have used the egg crate acoustic foam (PartsExpress) to insulate my in-ceiling surrounds and rear surrounds and have extra pieces that I can use. If there is better material I am open to suggestions.
I am also wondering if I should “isolate” the mains and/or the sub from the wood surfaces to reduce vibration transmission. As it is, I need to raise the mains about 1.5” to center the coaxial drivers in the speaker doors. There are a variety of products out there but I would appreciate some advice. Note that the sub does not have much room above so anything under it must be less than 1.5” high.
Here is the basic equipment involved in the cabinetry:
Yamaha RX-V2500
Bagend MM-8H (LCR mains)
Bagend Infrasub-12 Home (I-12)
Samsung HL-R6168w
Thanks.
Tom
