I am on a budget of 1,000 dollars. I have looked at so many receivers and speakers, I am not sure which direction to go in. This system will be going into a bedroom that has been turned into a tv room. The bedroom is not large. The primary use for this system will be to watch movies and tv shows. If you have any advice, that would be great.
With $1000 available now, I'd go for quality over quantity and map out a clear upgrade path to a full (5.2) system.
Start with a good solid 2.1 system comprising smaller bookshelf speakers (suitable for surround use later) and, for your sized room, a good quality compact sealed sub.
If you're coming from "not much", a properly set up good quality 2.1 system will keep a
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
on your face for a few months while you save to make your next purchase. The idea is to get a bit aspirational with your speaker shopping, pick a "family" of speakers you really
like and buy the small pair of bookshelves from that range. Ultimately, you'll end up with a much better system than buying the 5 speakers plus sub you can
afford now.
Edit: You'll need to do some research to satisfy yourself that the speaker line chosen will not be discontinued during the next 12 - 18 months.
If you're interested in pursuing the expandable 2.1 idea, here are some well regarded speaker "families" to get you started:
I'm sure there's some others I've forgotten...
Speakers: Of the above, my pick is the Ascend Acoustics
HTM-200 SE's. ($330 shipped.) These are a high performing sealed design that make ideal surrounds later. Subsequent steps involve moving towards
CMT-340 SE's for L/C/R. (Six matching 6.5" woofers across the front in a smaller room will be pretty special.)
Sub: No contest.
SVS SB-1000 | Black Ash | Outlet | 1239. ($450 shipped.)
AVR: Try to get yourself as far up the Audyssey pecking order as you can with a factory refurbished or used Denon.
Refurbished: DENON AVR-X1000 5.1 Channel Networking Receiver with AirPlay | Accessories4less. ($220 shipped.)
The next steps are:
- Matching centre channel (Run "phantom" mode 'till then.)
- Larger matching mains; move current ones to surrounds
- Audio measurement gear (Like this: Dayton Audio OmniMic V2 Precision Measurement System.)
- Second identical sub
- Down the rabbit hole...
