Help! HK 7200 set up.
mdrew
I just got the 7200 and a set of Axiom M80's this weekend. I have the Axioms running off the zone II and I'm using the HK remote sensor for multi room use. Everything is working the way it's suppose to as far as inputs and two sources playing in the two different rooms, but I can't seem to find out how to change receiver settings for zone II. Evan if I turn the bass/treble controls on the receiver, there is no difference is sound. They definitely change the sound in the main room, but not zone II.
Anyone have this unit that can shed some light??
thanks in advance........mike
mdrew
Well bummer…..I have been fiddling with this thing for two days now, and I’ve determined that the multi-zone is nothing more than a source input pass through. The only thing I can manipulate is the source selection and volume, and I’m locking into stereo without the ability to use the HK’s different X-overs or other base management functions.
I’m very pleased with the sound of the HK and Axioms as is, but not being able to adjust treble and bass is driving me nuts. I’ve just got to be able to play with things. Does anybody have some ideas how I can do that? Is this an excuse to buy some more equipment??
