Help HDMI connection
cliu
Hi I have a question about HDMI connection
Should I use a HDMI cable connect my blue ray player (Sony - UBP-X800) to my receiver (yamaha av 1070) first, then use another HDMI connect from the receiver to TV (sony 900e)
or use HDMI cable connect my blue ray player to my receiver first, then use another HDMI connect from the blue ray player to TV. What is the difference?
Blue Dude
Wrong forum, belongs in Beginners, not HTPC.
Anyway, the receiver is is intended to be permanently connected to the display. You should only bypass the receiver if there's a very good reason, such as your receiver is incapable of passing though the source signal intended for the display. The advantage is that the receiver does any video switching so you don't have to change inputs on both the receiver and the TV when you change sources. Also, the receiver overlays it's own information, such as input selection and volume. And you'll have a more difficult time setting up the receiver unless you run at least a temporary video line to your display to show the GUI.
