Help For A Novice!!
HOGGER
WHAT WOULD BE MY BEST CHOICE?
TOSHIBA TDP-T9U--$699
OPTOMA HD70--$999
INFOCUS IN72--$799 W/SCREEN
I HAVE HEARD GOOD REVIEWS ON THE OPTOMA AND INFOCUS.I AM BUILDING A SMALL ROOM (12X12) THEATRE ROOM. I WOULDN'T MIND SPENDING A COUPLE HUNDRED MORE IF THE DIFFERENCE WAS WORTH IT. ANY OTHER PROJECTORS BETTER FOR THE MONEY. IT WILL BE MOSTLY T.V AND DVD AND GAMES.
THANKS FOR THE HELP IN ADVANCE.:confused:
slickster
Hey Hogger welcome to the forum.
I don't know alot about different projectors. I bought mine through Complete IT Presentations and purchased an Infocus Screenplay 4805 about 16 months ago and have had no problems so far.
I can suggest to you that make sure the projector and size of screen you choose are okay for the size of room (distance from projector lens to screen).
My projector lens has to be about 12-14 feet to the screen for a 92" screen.
These numbers are very important when installing a screen/projector system.
I had just enough room....thank God.
You can ususally find these specs through the manufacturers website.
Just my thoughts.
Ciao for now.:cool:
HOGGER
Thanks For The Input Slickster!! I Need All The Help I Can Get.
