Palmettokid said:
I've poured over many posts in this forum and have realized that there are many different ways to approach my project. If you've read my previous post you'll know that I will be building a house this year and need some advice on what equipment to buy and where to place the surround sound system in the family room.
If those are windows on the "north" wall, the people in the chairs on the south side will be dealing with reflected glare in the evenings. A HT really wants to be in a room where windows can be completely blocked off at need.
The corridors in the "south" wall are going to make a mess of the room acoustics. Even just for movies, that can matter. Is it too late to redesign the room? You've got a good sized space there (a large room is a prerequsite to a really great HT), but the acoustics are going to be tough to work around. It will sound lopsided, and sometimes boomy.
You don't have a good place to put the center channel, with a fireplace right there, so you will probably end up with a phantom center, which means you need good main speakers and halfway decent electronics. I'd look at a Denon A/V player, and maybe VMPS RM-30/CDWG for the main speakers. Of course, that's a hunk of your $5k right there, but you can use pretty much anything you like for the surrounds/rear/sub speakers just to start. They just aren't that critical. (Well, a good sub is, but there's no point in buying a sub until you know how your room reacts to bass.) Speakers are always the most important component; it's better to buy 2 good speakers you can keep for years, and some throwaways for back and side channels, then to try to get 4-7 "okish" speakers, none of which you'll be really happy with down the road.
Your room is big enough for a projector and screen. The screen can be painted on a flat wall if you decide not to use the fireplace as the video point. I love mine - it's a real popcorn experience.
