HELP! Denon AVR-3805 VS. Yamaha RX-V2400
U
Unregistered
Guest
Hello,
I'm new to this site and wanted to see if anyone had some feedback on the two receivers. I keep going back and forth with these receivers. I'm looking for a kick a*s*s receiver and to get the most "bang (or boom) for my buck". I've researched them both extensively but can't decide! Help!!
This is what I currently have set up:
JBL Studio S412P front
JBL Studio S-38 Surround
JBL Studio S-Center
Kenwood 103SW Sub
Sony DVP S-7700 DVD
Sony 41" HDTV
Thanks!
Evan
BIG FISH
Altough I was comparing the Denon 2805 vs. Yammie's 1400, I ended up chosing the Denon. I just liked the sound of the Denon better. At the store I made sure that I could bring back the Denon If I didn't like it when I brought it home. I'll tell you, once I set it up, I knew I was not bringing this unit back.
Sounds awsome!!!!!!!
All in all, find a place that carry your line of speakers so you can get a better idea of the sound these two recievers will produce with your speakers. Make sure if your not happy with the reciever that you can take it back. Good luck!
