[Help] Denon avr-3805 auto standby
  • Thread starter Thread starter vincent009
V
vincent009
1
0
0
I go nut with my denon avr-3805 lately. everytimes i turn the volume little bit lound it start turn on standby feature. I can't turn up the volume too loud from now..... just fairly to listen. I can't figure out why. could someone tell me how to fix this thing??? is my denon avr-3805 burn??? I want to listen it loud but keep turn off to standby mode..... HELLLLLLLPPPPPPPPP
Re-Initialize the processor
I am not a techie by any stretch of the imagination, but I would start by checking my speaker connections and making sure that they are not cross-polarized or frayed in such a way that they are touching each other; either at the speaker or otherwise. Next I would re-initialize the processor (page 97 of the Owner's Manual @ http://usa.denon.com/AVR3805_DFU_ownersmanual.pdf explains this in detail).
  • Like
Reactions: Snap
Something is drawing to much current that is for sure. Also try and remove speakers. Like just have the mains hooked up. See if you can isolate it down. Find out who is the bad guy. Then see if it is the speaker or the chan that is bad.
