HELP Denon 3806 Vs yamaha AX-v2600
  • Thread starter Thread starter benignoh
benignoh
4
0
0
what are the main difference betwen this two.
what is the best pick base on experience?
thanks
Benny
While I have not owned a 3806 I have had a 2803 and a 2805, a RXV 2500 and 2600. I would say if you never plan on using an RTA to manually setup the PEQ, then get the 3806 because it's auto PEQ is more accurate. However, if you want manually override of the PEQ then the Yammie is the way to go.
I am interested in the same question. I have been looking at both receivers. I know the 2600 is listed under product of the year and must be a strong performer but I have not seen much about the 3806.
Also I have just purchased 4 ohm onix ref. package and want to find the best receiver to go with them.
Would also love to hear some thoughts from the group.
