Help! Crown CDi-1000 amp locked
Jay1979
Hello,
I'm in need of some help unlocking my amp I just bought from someone. Long story short, I have a home audio system including outside speakers, etc and want to use the Crown CDi-1000 to make them louder, etc. Issue is the thing is locked. I tried holding the two buttons at the same time but that didn't work. What do I need to do? I'm desperate to get this working. Any help would be great.
Thanks,
Jay
slipperybidness
slipperybidness
1) Read the manual!
2) Contact the person that sold it to you and ask them!
Jay1979
Yeah, I have no manual but I did read it online. Doesn't really say... I am trying to contact the person but of course they are MIA.
Jay1979
I'm missing the green colored prong connector on the back where the channel 1 and 2 are. Is this a univeral connector I can buy anywhere like a Best Buy? Not sure why it wasn't sent to me with it but I'm missing that and a USB cord...
Is this amp hot? Kinda sounds like it.
Jay1979
Well, I bought it on Ebay. I'm starting to question it. Seller is hiding from me too.
Jay1979
The seller says it's definitely not. He just replied to me. So I guess I'll try to figure this out.
Reke4
[QUOTE = "Jay1979, publicación: 1096748, miembro: 76243"]
Hola,
Necesito ayuda para desbloquear mi amplificador que le acabo de comprar a alguien. Para resumir, tengo un sistema de audio doméstico que incluye altavoces externos, etc. y quiero usar el Crown CDi-1000 para hacerlos más fuertes, etc. El problema es que la cosa está bloqueada. Intenté mantener presionados los dos botones al mismo tiempo, pero no funcionó. ¿Que necesito hacer? Estoy desesperado por que esto funcione. Cualquier ayuda sería genial.
Gracias,
Arrendajo
[/CITAR]
Yo tambien tengo un amplificador Crown CDI 1000 con el panel frontal bloqueado ayuda que me recomiendan lo e buscando tutoriales y nada
FWIW the green connectors sound like phoenix connectors....not unusual on pro amps.
