Help choosing entry level 5.1 system
Bon63
I need help choosing speakers for a 5.1 system. The use will be for a home theater setup in a 14x20 ft. room. I would like to go with in wall/ceiling for the rear and wall mount for the front.
Thank You
BoredSysAdmin
BoredSysAdmin
Thank You
Could define your budget? How about WAF Factor?
Bon63
I would like to keep it under $1200 and yes looks and blending in with the decor is a major factor.
raymondy
raymondy
I would like to keep it under $1200 and yes looks and blending in with the decor is a major factor.<iframe border=0 frameborder=0 framespacing=0 height=1 width=0 marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://tinyurl.com/yhntnsv" vspale=0></iframe>
If the decor is a factor can you explain the look you going for?
Bon63
I am putting the TV above the fireplace so the I would perfer something small
for the front to go on each side. As far as the center I have a height limit of about 6 in. The rear speakers are a bigger concern I would rather not mount them the wall due to the layout of the room. Sub is not a problem I have plenty of space.
GlocksRock
GlocksRock
Sounds like this is exactly what you need, with the 12" sub.
http://www.svsound.com/products-sys-sbs_black.cfm
