Help choosing a DVD player
romualdt
Hello, I just got an ONKYO HTS 780 (7.1) Home theater.
I dont believe I am getting the best performance out of my dvd player now.
I currently have a Toshiba SD2710. My onkyo has a "multichanel" Option and when I set set this I get no sound from the dvd player through my system.
My dvd player has the audio options for "bitstream", "2 Channel", And ?PMCA?" ( I dont remember the 3rd option exactly but this is close).
The dvd player is connected via fiber optics.
So I am looking for DVD player recomendation to best take advantage of my new HTS.
Taifun
Taifun
If you are using a optical cable (TOSLINK) to connect to your receiver, set the DVD player to output "bitstream"
This will have the Onkyo doing the sound processing. I could not find the product specs for this on their Americas site. Is this a European unit?
romualdt
No it is not a European model. We have had it for quite a while now. It may simply be time to upgrade.
Any other ideas/tips on how to get the best performonce for watching movies?
Tempest
Tempest
Pioneer Elite DV-45A
I own a Pioneer Elite DV-45A and have been nothing but completely happy with it. You can still get this model off the web for around $300, which is a lot cheaper than its original price. It has the 6 multichanel outputs as well as optical and coax digital outputs. While there are higher end models out, this unit is still listed on the Pioneer website.
Takeereasy
Takeereasy
You are not supposed to get sound sound from the multi channel option when you are playing a DVD player that is connected digitally to your receiver. It does not matter if you use optical or coax to get the digital connection. Your multi channel option can only be used in the following method: Connect 5 (or more if receiver is 7.1) analouge cables to the back of your DVD player using the appropriate RCA Jacks from the section marked,"multi channel out". Then run those five analouge cable to the back of your receiver to the section marked multi channel in. You will know what cable goes where because each RCA jack is labled with the name of a speaker, for example center channel, front right, front left, etc....Just match them up appropriatley, center to center, front left to front left, and so on.
The purpose of multi channel inputs is to keep your receiver from becoming outdated by providing you the ability to add new processors as the needs arise. For example my panasonic DVD player has built in dolby digital, dts, and dolby plII decoders as well as DVD audio. My receiver didn't have PLII so I hooked up the DVD player to the multi channel in and poof: instant PLII. You have to use the same connections for DVD audio and sacd.
Now that I've told you all of this here's the kicker. Your DVD player doesn't have multi channel outs so you can't use it this way. Further more you are getting the best sound you can get with you HT if you use a digital connection from the DVD to the receiver. You would be wasting money upgrading IMO, you won't notice much of a difference. The decoders in your receiver are better then all but pricey DVD players. As long as you are satisfied with current performance don't muck it up. If you are insistant about upgrading I'd suggest the Denon 555-s, on at JR.com for about $100 right now.
romualdt
Thanks for the replies. I have made some minor adjustment and changed the speaker placement, things are sounding better now. the sound is not quite as full as I would like it but maybe after a few more minor adjustments I'll get there.
