Hey! I'm a long-time lurker of these forums and I now have a reason to come to you all for advice!
Preface:
Currently I'm moving to a new house that was built over 90 years ago, and I'm going to convert the unfinished attic into my bedroom. I made a rough sketch of what the attic looks like in a structural sense:
All the walls are just open with exposed insulation, mainly 2x4s with plenty of bracing. My plan is to drywall all the sloped walls and celling, and paint the whole room.
I will also have access to custom wiring since the attic will need to be rewired anyway (since it currently has 90 year old wiring)
The stairwell comes up around the center of the room, as you can see in the picture.
I have no real budget restrictions on the construction portion of the project.
Current Audio Equipment:
As I am a high school student and don't have a money tree growing in my yard, I'll probably use some of my existing speakers to compliment my setup. Here are the two sets of speakers I currently have:
Polk Audio Bookshelves -pair- (cira 1990-ish)
And some larger Klipsch Speakers -pair- (cira 1990-ish)
*sorry for the grainy pics, used my phone
Anyway, I also have plenty of speaker wire and other stuff.
Needed Audio Equipment:
I will probably want to put together a 5.1 or 6.1 system, since there is no obvious "front" of the room. I would want a good center speaker or a pair of bookshelves to give the room a suround-sound feel.
I also need a subwoofer that can dish it out but not get too distorted in such a small room. I love bass, and make my own songs on my iMac to take advantage of a powerful sub, so 300+ watts and 18- Hz would be nice.
Finally I will need a receiver that can support:
-- my iPod ( I have an cable for the red/black input)
-- A CD changer (Yamaha 5-disk)
-- Lots of speakers (7) and subwoofer
-- Good EQ
-- Remote Control
I need a receiver that can drive my speakers cleanly, but I don't need killer wattage.
Review:
+Center or Pair of bookshelves
+Subwoofer
+Receiver
I have a smaller room, and I will mostly play music with it, as I don't have current plans for a TV.
My budget:
$1000 give or take some, but not much higher...
Please recomend what I should get and how I should set it up!
World Leader
