Help: Broken binding post
K
kbone78
One of the binding posts on my Denon 3803 is broken. Specifically, the part that screws in is missing the metal sleeve inside making connecting banana plugs impossible.
Is this easily fixable? ie going to radio shack, buying a binding post and using just the screw part that I need?
sjdgpt
Radio Shack, the friend of every do it yourselfer.
Sounds like you got a plan.
It should work with no problem.
