Looking at outlaw7000 or monolith 7 which do u think is better first actuall power amp
P Paul s Enthusiast Mar 29, 2020 #1 Looking at outlaw7000 or monolith 7 which do u think is better first actuall power amp
G Gmoney Audioholic Ninja Mar 29, 2020 #2 Two really good amps both will Performe admirably. Last edited: Mar 29, 2020
P Paul s Enthusiast Mar 29, 2020 #3 Gmoney said: Two really good amps both will Performed admirably. Click to expand... Using with pioneer 503 elite receiver
lovinthehd Audioholic Jedi Mar 29, 2020 #4 They're not particularly comparable. The Monolith is a more powerful amp and Outlaw less expensive....so what is better for your needs?
P Paul s Enthusiast Mar 29, 2020 #5 lovinthehd said: They're not particularly comparable. The Monolith is a more powerful amp and Outlaw less expensive....so what is better for your needs? Click to expand... I guess better ? Wich is better built i was trying to figure if mono was worth the extra 500
lovinthehd Audioholic Jedi Mar 29, 2020 #6 Paul s said: I guess better ? Wich is better built i was trying to figure if mono was worth the extra 500 Click to expand... The ATI-built Monolith could have the edge there but no one will really know for about 20 more years Why do you need 7ch of equal amplification particularly?
P Paul s Enthusiast Mar 29, 2020 #7 lovinthehd said: The ATI-built Monolith could have the edge there but no one will really know for about 20 more years Why do you need 7ch of equal amplification particularly? Click to expand...
P Paul s Enthusiast Mar 29, 2020 #8 lovinthehd said: The ATI-built Monolith could have the edge there but no one will really know for about 20 more years Why do you need 7ch of equal amplification particularly? Click to expand... Using 4 klipsh rp8000 polk sur center klipsh for height and 4 primus 363 for othet room plus 2 subs
lovinthehd Audioholic Jedi Mar 29, 2020 #9 Paul s said: Using 4 klipsh rp8000 polk sur center klipsh for height and 4 primus 363 for othet room plus 2 subs Click to expand... Whut? Doesn't really answer my question but more confusing than anything. You have passive subs?
P Paul s Enthusiast Mar 30, 2020 #10 lovinthehd said: Whut? Doesn't really answer my question but more confusing than anything. You have passive subs? Click to expand... No powered iM running 9 speakers not counting 4 primus dont have power for them using pioneer 503 elite but not really enough power for all
Verdinut Audioholic Spartan Mar 30, 2020 #11 Both the Klipsch and the Primus speakers have a rather high sensitivity. Either the Outlaw or the Monolith should be adequate for your needs. There would be slightly more headroom with the Monolith if your main listening room is large, your listening distance from the main speakers is over 12 feet and you listen to your system at reference level. Here is a link to calculate what would be adequate in your situation: http://myhometheater.homestead.com/splcalculator.html
