O
omgxnolife
im new to the Vinyl world and I just need a few pointers / beginner(budget) setup ideas etc
tmurnin
tmurnin
Maybe help us out by describing what you want help with. Equipment selection? How to set up a system? Do you already have a sound system but you're wanting to try adding a turntable? A few more specifics would help.
Pyrrho
Pyrrho
Not only should you tell us what you already have, you should tell us your exact budget. A "budget" system for one person is not what another person would call a budget system. I would consider a $1000 system a budget system.
If you have nothing, and want to go cheaper than that, I would recommend forgetting about going with a turntable, as good ones cost money.
O
omgxnolife
i have NO equipment and my budget would be ehhhh roughly 850.
im not getting into djing or anything.
i just need a basic in home setup. (sounds decent and wont break the bank lololol)
is that better? xD
