HDTV what does this mean?
Frankie
Frankie
Can any help?
High Definition video – from HDTV broadcasting or HD package media – is bringing the European consumer the single most important advancement in image quality since the introduction of colour TV.
Requirements for the label “HD ready”
A display device has to cover the following requirements to be awarded the label “HD ready”:
1. Display, display engine· The minimum native resolution of the display (e.g. LCD, PDP) or display engine (e.g. DLP) is 720 physical lines in wide aspect ratio.
2. Video Interfaces· The display device accepts HD input via:analogue YPbPr1, and DVI or HDMI HD capable inputs accept the following HD video formats:
1280x720 @ 50 and 60Hz progressive (“720p”), and
1920x1080 @ 50 and 60Hz interlaced (“1080i”)
Does HDTV signal mean in terms of quality on the TV will it be better than DVD?
BMXTRIX
BMXTRIX
DVD only carries 480 lines of resolution, and it is a 4:3 image. HDTV has two (current) standards 720p and 1080i which are 720 and 1080 lines of resolution presented in a 16:9 format (widescreen). It's about twice the resolution of DVD.
The reality of your DISPLAY DEVICE: Unless you get a CRT television, then you are likely going to have a fixed pixel display. That is, it will have a very specific resolution. Let's say, it has a resolution of 1280 pixels wide, by 720 pixels tall. Then, no matter WHAT resolution you send it, it is only capable of displaying, at most, 1280 pixels wide, by 720 pixels tall. It will convert the 480 lines of television and DVD to 720 lines. It will (likely) have the ability to stretch the 4:3 image across all 1280 pixels of width.
But, send it 1080i, which is 1920 x 1080 pixels, and it must shrink the image down to fit 1280x720.
Send it 720p then you are sending the native resolution of the display of 1280x720 pixels.
The quality of a television can vary greatly, but most of all you must stand back from the television about as far as you will be when you are typically viewing it to evaluate the picture quality. A 42 inch plasma that is 1365x768 pixels and costs $6,000.00 may not offer any visible improvement over a 42 inch plasma that is 853x480 pixels for under $3,000.00 if you are sitting more than 12 feet from the display. Depending on your typical viewing, it may even offer a better image or better color or contrast.
Lots of choices and lots of wild swings in pricing at every price point.
bbakken82
I do believe 1920x1080 is 1080p. honest mistake
Frankie
Frankie
Unless like me you come from UK which offers 560 lines.
Please can you tell me how a CRT HDTV works as Plasma Screen are now very clear, but i do not understand how CRT works w.r.t HD picture?
What determines which CRT TV will be the better one
I would say that depends on your source such a DVD via HDMI.
Yes this can be true, but just as having the correct calibration and the correct lighting in the room can make or break the quality of the picture.
I believe you get what you pay for. :)
BMXTRIX
BMXTRIX
Rear projection CRT television uses 3 separate cathode ray tubes and lenses to create an image on the back of a screen. Read details of it: http://electronics.howstuffworks.com/tv.htm
CRT Technology is most definitely a long drawn out explanation, but it is still considered by many to be the standard by which all other displays are to be measured against.
Most regular CRT televisions, the ones that are not projection, but are about 34" or smaller and are HDTV are usually of very good quality, often in a cheap plastic case. What determines what makes one better than another is measured in labs as much as anywhere else. Good materials, excellent color, good image processing. The same things that make all other displays good also apply to CRT, but CRT will almost always handle shadow details far better and therefore have superior contrast ratio.
Source, such as DVD via HDMI has very little to do with image quality. Pixel size, image processing, color, and shadow detail make up the image. Pixels are only distinguishable to the human eye when you are within a certain distance of the display. So, the 42" EDTV plasma that has good color, shadows, processing, etc. can appear as good as a plasma costing thousands more MUCH more often than people are led to believe. This is marketing hype. It is also very common for people to believe that HDMI and DVI digital connections provide a superior image than component, when in the labs it is about a 50/50 toss up as to when the digital connection is going to provide a better image. ESPECIALLY with DVD players. Upconverted DVD is not necessarily better than the regular DVD footage on the disc going into your TV via component cables, and if the processing is poor inside the DVD player, then the image almost is guaranteed to be worse.
There is a lot that determines image quality, but given two displays of the same size and the same technology both of them ISF calibrated, price is usually a factor in the quality, but once again, not always. You also have to consider reliability and customer service if it is necessary. Sony often provides a top notch TV, but if you need to contact Sony for customer support... GOOD LUCK! Other larger companies are also very poor with customer service, but they produce excellent displays and you hope you never have to call them.
The bottom line for me is that almost every display out there is NOT properly calibrated and typically is not viewable in 'home' type viewing situations. This makes it exteremely difficult to accurately judge the quality of any display. Magazines almost all do a piss-poor job of honest analysis and review, which leaves a lot of websites which are often in the same situation of not being readily able to give poor reviews of any product. So, you are usually in better shape by paying more, but it most definitely is not a guarantee... IE: Runco.
Frankie
Frankie
IE: Runco.
Thanks for the info.
HDTV is here to stay and will take time to bed. Once we are all turned on to High Definition TV, i am sure that the next Best Thing to turn Heads will be 3-D. ;) TV​
