HDTV to AVR connection Question
MDS
The back of the receiver has several places marked 'monitor out'. If you use component video cables, use the one in the component video section (upper right hand corner) and connect the 3 cables to the component video input on the HDTV. Then select that input on the TV; ie if the tv input is labeled 'video 1', select video 1 on the tv.
F
Fl_Gulfer
I know how to connect my components to my TV I'm asking how to connect my Monitor Out on the TV back to the Receiver, when you run a cable line that has no box to your A or B inputs you have to have the sound go from the TV to your receiver. There is no Monitor in on the back of the Receiver like my old one had.
sanoel
Just use one of the 6 audio inputs you have on the back of your Denon. if it was me i would use the one for the TV/DBS. Hope that helps
