I thought I saw the answer to this earlier, but darned if I can find it again...
I am thinking of buying an HDTV monitor (no built in tuner). I just intend on using basic cable to begin with (I know it won't receive HDTV signals). The question is "Can I run the basic cable, with no set top box, into the monitor, or would that still require a tuner?" Or is the tuner only needed if I want digital and HDTV?
I will probably get a HD cable box from the cable company later, but $ is a bit tight now.
thanks-
