I have an older (P50XHA30WS) Fujitsu plasma monitor (no tuner or sound) that only has a DVI input. I want to upgrade my old JVC 5.1 receiver to a HDMI AVR unit.
My current setup is: Blu-ray works ok (directly to the TV) using HDMI with a converter cable. My other components work ok using component (RGB) connections on the TV.
With a HDMI AVR: I will connect my DishDVR, Blu-ray & Xbox to the receiver (via HDMI), then HDMI video out (from the receiver) to the TV using a converter cable.
I'm finding some HDMI receivers are not compatible with a DVI port (which is HDCP complaint). Can anyone suggest a HDMI receiver that will display video to a DVI port?
