SackoHammers said:
Are HDMI connectors just a consolidation of conductors?
Lets say 2 years from now I have a 1080p television with HDMI input and Component input.
Is there an advantage to using HDMI on my HD cable box and HDMI on my DVD player over simply using Component from my cable box and Component from my DVD player?
Does it offer something that Component does not in the way of bandwidth? For example, will I find out that I can't do 1080p through component, then necessitating HDMI?
If all it's doing is consolidating wires then I'm not going to waste money on making sure my AVR purchase does HDMI switching.
Your help is greatly appreciated.
HDMI is a digital connection, and component is analog. With a digital source and a digital display (such as an HDTV), if you use component, the video is converted from digital to analog and then sent via the component wire, then converted back to digital again. With HDMI, it is digital all the way. Whether you will see a difference or not will depend upon the particular equipment involved, but the extra conversions back and forth between analog and digital with component video are not going to do the picture any good.
So, no, it is not merely a consolidation of conductors.
Yes, there is an advantage to using HDMI for an HD cable box and a DVD player. The signal remains digital all the way.
1080p can be sent either way. However, not all products are compatible with 1080p inputs, even if, for example, it is a 1080p display that upconverts all incoming signals to 1080p. There are also the copy protection issues, that can make it so that a product will automatically downconvert for the component transfer. Also, there have been bugs in the system, causing problems in some cases with HDMI.
You may not need the switching, if your TV has two HDMI inputs, or an HDMI input and a DVI input, as an adapter can be used to hook up HDMI and DVI (though then it will only be the video that is passed, as DVI is video only).
