I might be wrong...about many things
GlocksRock said:
So is it possible for any current devices using HDMI 1.1 to be upgraded via firmware to HDMI 1.2a, like my Yamaha RX-V1600 for example?
The way I understand it is not firmware upgradeable. Only backwards compatible. Kind of like USB 1.0 - 2.0 type thing. The hardware itself is different.
The plan is for you to buy a RX-V1600a, RX-V1601, RX-V1602 etc on a yearly basis if you want to be current.
Is any one else dissapointed by the lack of progress at CES this year? It should have been called CES 2005a. Quote from CES booth chucklehead "Just look at all this cool stuff thats only 6 months to a year away...same stuff as last year".
I bet 5 years minimum to get everything sorted out to a level to put a system together with a reasonable shelf life and compatibility. Maybe even a little content.
The 2006 digital deadline barely gets me to raise an eyebrow. SD digital broadcast...big deal.
In 2011(if I'm lucky) I'll have my dual tuner cable card HD tivo, High res audio/video reciever, HD optical device dejour, only 3 cables in the system (not counting speaker cable) and stacks of content from cable/bigbox/netflix. It's gonna be sweet!
BTW Glocks are pretty cool if you don't shoot that often. I'll take the full size 10mm model. The Glock 20 I believe. MMMMMMMMMMMMMMM 10mm
