I'm hooking up my HT and seem to be having a few issues. My equipment is as follows:
Yamaha RX-V863 Receiver (2 hdmi in, 1 hdmi out)
Xbox 360 Elite (w/ hdmi)
Samsung 52" LN52A550 LCD TV (3 hdmi in)
Cable box (1 HDMI)
The way I have it configured is correct unless I'm misunderstanding HDMI. I've run the xbox & the cable box to the receiver HDMI in's and then the receiver to the TV via the HDMI out (on the receiver). This should allow me to completely disable the sound on the television, right? Apparently this isn't the case. I can play movies/games, etc. and get the sound from the receiver by switching the receiver to 'DVD' since the hdmi cable out to the xbox is plugged into the receiver slot marked DVD. However, when watching cable TV, I get video but no sound.
I've switched cables and it still doesn't work if it's going out to the cable box. I've used the 'sattelite/cable' hdmi port in the receiver with the xbox and it works which leads me to believe it's nothing in the hardware.
I'm not sure if it is significant but i currently only have a front speaker and the sub hooked up (I'm waiting on the rest of my speakers to come in). I wanted to get the receiver and everything hooked up so all I have to do is wire in the speakers once they arrive. Anyhow, any suggestions would be appreciated.
