tsfdirect said:
I have a Yamaha RX-V757 Receiver, Samsung 56" DLP (1080p), Motorola HD cable box and surround sound. I'm currently using component in and optical to the receiver from cable box and back out from receiver to TV. Sometimes the audio and video are not in sync. I want to use HDMI to get the best picture quality. If I use HDMI from cable box directly to receiver, do I still need to have component connections from receiver to tv? I have I want to use HDMI from cable to TV, since I can't connect this way through the receiver. What is the best way to then connect audio? Very confusing! Any suggestions?
If I am understanding you correctly it sounds like you should be able to run an HDMI from the cable box straight to the DLP TV. That should carry an HD signal as well as a digital sound signal to your TV.
Now, the second part of the puzzle would lead to connecting your TV to your receiver so that it carries the sound signal over. Again, if using optical there may be a lag time since optical consists of light pulses so the signal may get to the source ahead of the HDMI signal. If not then I would suggest running a component cable from the TV to the receiver. Since component consits of electrical pulses I would suggest purchasing a jacket for the cable in order to reduce the amount of "noise" picked up by the electrical pulses. What other types of inputs does the receiver have that the TV can output to?
As far as the HDMI cable goes....there are a variety of them and most consumers may not understand the differences. For example, at the end of the cable, is there a strain relief spring installed? This helps with the sauder points and delivery of a true signal. I have, and continue to use, Accell cables. They have by far the best, for their price point, cables on the market. I hope I have helped.
