HDMI 101 {question}
Φ
ΦBentBrotherΦ
Is there REALLY any BIG difference in performance/picture quality in a HDMI cable that is ►$7.99 or ► $79.99.? I hear that they either WORK....or they DON'T- is it that simple.?
BB
1st post -
I have no gear ..... just yet- :(
jamie2112
Buy your HDMI cable here: www.monoprice.com. Whatever you do DO NOT BUY MONSTER CABLE........monoprice has quality cables for a fraction of the overpriced crap monster sells.....
Adam
Adam
Welcome to the forum!
That's not quite as simple as a "yes" or "no" answer. There are some good articles that explain it. I'll see if I can track them down.
Typically, though, the cheaper cable will perform just as well for most people's applications. Are you looking to buy a cable, and if so, how long of a cable?
ParadigmDawg
ParadigmDawg
Ha...I finally beat Adam to a response....
businessjeff
clearly its obvious.... The more money you spend, the better you feel, which equates into tremendous audio video performance... duh. Why do you think monster cables are the best! They make you feel good, and we all know that we perceive audio and video with the feelings they invoke, not silly things like our sight and hearing.
Its all about the psychoacoustics marketing.
http://en.wikipedia.org/wiki/Psychoacoustic
So, spend as much money as you can on a single cable, the ideal situation would definitely call for a 2nd maybe even 3rd mortgage to fund the best cables known to man, I mean monster.
I hope this clears things up for you, cheers.;););)
Seth=L
Seth=L
At short lengths almost any HDMI cable is capable of handling all current bandwidth capacity needed for audio/video. If the signal is getting through, there isn't a problem. Drop outs can occur at longer lengths with improperly sheilded or cables with high natural resistance. Resistance also increases as the length increases.
jamie2112
LMMFAO......too funny. Unless of course you are serious and in that case you should be shot.........:D
I also agree with Adam on the Monoprice HDMI cables. I've compared the buid quality on the Monoprice HDMI cables vs the less expensive BJC HDMI, and they are the same. In other words, they are both very good quality.
Nemo128
Nemo128
I think the above best answers the question objectively. Kudos Seth.
Φ
ΦBentBrotherΦ
Thanks guys→ I get the picture.... or will, after I get my cables and
myG E A R. :D
