Oops.. I did not know enough about speaker types to know that Transmission Line is not also a type of horn... But... I do know how to follow plans, and to a lesser degree, how to select them.
After hearing single driver speakers, I am hooked....
For the center channel, since I cannot find a suitable plan, I had planned on either adapting the Jordan VTL plan ( from their website) (It is the VTL cabinet design that are my mains) preserving the dimensions, but making it a horizontal box to fit the space, or building a twin mouth horn like the Cardersound Kyler. I have researched and built enough horn designs to get myself in trouble....
As an aside, there are a number of plans at 'Spawn Family of Double Horns'
Some of these sound quite good.. Also a neat looking design for the Jordan driver at mh-audio.nl
I just picked up a pair of Audio Nirvana Cast Super 8 drivers, couldn't help it, the price was right.. I will probably try them somewhere in the system after they are in cabinets.
The idea of a receiver did give me the 'willies' for the reasons mentioned. I have never owned a receiver either. Space is a concern, the rack is already large, loaded with turntables and associated gear, I was looking forward to a single unit that 'did sound' for the AV portion. It would be a problem if the lesser quality 5.1 system did not sound as interesting for movies as the 2 channel system.
Interesting reading your review of the Audessey system, I wondered if it is necessary.. Theoretically it sounds good, but engineering beforehand, combined with quality gear should go a long way towards this, and keeping the clutter out of the signal chain has it's benefits. The Oppo has a reasonably detailed setup for calculating delay for speaker locations.
What about using an older, but high quality AV pre/pro, only for the sound? Something simple , with no room correction, delays, nothing but a gain to control five channels and a sub.. using the setup in the Oppo for speaker delay.
Also, What about the sub? Is a downward firing 18" in a sealed box too much?
You have a lot of confusion. Your VTL cabinets are a variety of TL, known as an acoustic labyrinth. It is not a horn. The Spawn Family designs are horns, However they are in no way suitable for the Jordan drivers. For horns you need low Q drivers, and the Jordans are fairly high.
I go back a ways with Ted Jordan. I was present when Ted and Leslie Watts first demonstrated the Jordan Watts Mk1 module in April 1961.
The Mk 1 had a half life of 20 minutes! So over the debacle Ted left and the Mk2 had to be developed.
When I was in Canada during the seventies, I was the Canadian agent for Jordan Watts. I was largely responsible for the Mk 3 module.
Your driver is the direct descendant of the Jordan Watts module.
Here is a link to my Jordan Watts page, where you can also stream an interview I did with Leslie Watts back in 1976.
If you want an older pre/pro then I have
one for sale.
I think an 18 sub will be fine, but not down firing. You will need to cross the Jordans over at 100 Hz at least.
I am still a full ranger at heart, however the modules and Ted's unit are outclassed. The unit is a good midrange driver. However for modern digital sources, with the large dynamic range they no longer really cut it.
I do however keep a pair of TL loaded modules as reference to keep mo honest. If any speakers of mine have a significantly different tonal balance to those modules, I know there is trouble to look for.
May be you could post pictures of your rack?
Here is my studio album.
Here is my construction album.
I thoroughly recommend that center speaker. That SEAS coaxial is excellent. Those Audio Nirvana speakers look nasty, with very old fashioned rolled surrounds.
I looked at the TL part of the Ah site, and it is rife with error.
The best small full ranger for horn loading is the Lowther. That is easily the best full ranger for horn loading, with a pedigree right back to Paul Voight who founded the company before WW II.
However even they are outclassed now.
I moved away from single full range drivers in 1984 at the coming of age of the digital era. From then on the current crop of full rangers do not give the required all round performance.
However with the right facilities and money, I'm sure I could develop the JW module into a high powered mid unit from 200 Hz to 6 kHz. If we had a really good high powered midband driver that di not have to be crossed in the speech discrimination band, it would be a big advance.
Let me know if you are interested in the Rotel pre/pro.
