daphy
Hi,
some questions concering disc formats:
What exactly is HDCD, or better what kind of audio stream is behind this format?
AFAIK it should be a 24bit 44.1KHz stereo track, a friend comes along and tells me it must be something like a DTS stream multichannel because at work they use a DTS encoder which offers HDCD support.
I am a little clueless about this - if a HDCD is a PCM track one should be able to replay it on a simple digitally connected CD player/the same should happen if the source has something to do with DTS but the diffrence is shown on the receiver in the source input menue from Yamaha f.e.
(I don´t own such disc so) pls can you give a clue who´s right!
Thank you
Thank you
