HD Radio Tuner, Antenna needed?
BG3
If a receiver has a built-in HD Radio tuner, do you need a specific antenna for reception?
Yes, the HD, which isn't, is broadcast with FM signals largely and some AM. Good radio reception both analog and digital starts with a good roof antenna.
Winegard are the best. I had one last over 25 years, in the harsh conditions of the ND Red River Valley.
http://www.winegard.com/offair/fm.htm
BG3
I already have an HD TV antenna on the roof and I'm not sure I want two antennas up there. Is it possible to use a splitter to send one cable to the TV and the other to the receiver w/o destroying the signal quality?
In that case use this antenna.
http://www.winegard.com/offair/vhfuhf.htm
A splitter will be fine, you will loose 3db of signal to the TV and HD radio. Unless you are in marginal area, this will not matter a bit.
BG3
By your reply, I'm assuming there's a specific one you suggest? There are quite a few on that page and besides the elements and measurements, I'm not sure what the difference is. Please excuse my ignorance :confused:
markw
Actually, most HDTV is broadcast over the UHF band. While that Winegard antenna is, assuming it has adequate range for the target stations, an excellent VHF/FM antenna, it lacks the all-important UHF band upon which HDTV thrives.
I think a similar VHF/UHF/FM antenna might be better suited for this purpose.
Sorry, I forgot the second time you wanted it for HDTV as well. This is the one I originally picked out. The site goes to the generic page. This is really what you need.
HD8200P
