krzywica said:
He does'nt have digital cable, ie no set top box.
I know pip has nothing to do with tuning, but it sounds like he wants to view two sources (local broadcasts and Cable) at the same time.
I'm not sure if he's asking about pip capability, or inputs?
Not "at the same time" but, I want to be able to flip channels getting all the locals thru the anntenna, and then as I flip have the tv automatically pick up the cable for the other channels. so yes, inputs.
I don't have any kind of set top box, so I would be feeding the anntenna and the cable leads both to the tv directly. this unit seems to have two rf inputs.
I was talking to the
luminaries
at best buy, and they said that this would be possible, and all I would have to do is config in the tv's menus how to recieve any given channel (cable or anntenna). anyone know if its true or not?
reading the manual for that samsung online, it looks like for each channel I can pick an input type, ant or cable, but it wasn't totally clear to me, and also, what do you do in the situation were say the local abc channel brodcasts on channel 25 and my cable espn is also channel 25. if I choose the antenna as input for 25,
anyone of you doing something like this?
