hopper12
I dusted off some old hd DVDs today..I have the thought that this format still has a little bit of sound and picture quality over blue ray.. It has me in a search for old hddvds on eBay... Anyone else have the same opinion ??
Pyrrho
Pyrrho
You are likely comparing different masterings, and consequently, you may prefer one over the other without the format being any better at all. Several of the video and audio codecs are the same for both:
https://en.wikipedia.org/wiki/Comparison_of_high_definition_optical_disc_formats
However, BD allows for greater data transfer per second, so if an HD DVD looks better than a particular BD, it will be due to different mastering. BD is the better format.
Pyrrho
Pyrrho
For some reason, there is a problem with my link (though it is named properly, it links to the wrong site). Here it is again:
If one looks at the codecs, one can see that both disc formats support both lossy and lossless audio. If a studio chose to put a lossy soundtrack on a BD, but a lossless one on the HD DVD, then the HD DVD may sound better even if made from the same mastering and only converted to the respective codecs. That, however, is not the fault of the format, but a matter of what choices a studio makes in producing the discs. Both BD and HD DVD are capable of a great picture and great sound. But still, BD allows for greater data transfer per second, as well as having a greater data capacity, so it is the better format. But the lack of region coding on HD DVD is better, as it means that one can view any HD DVD on any HD DVD player, unlike BDs that have been region encoded.
Nope, not really. You should have picked them up when Toshiba dropped the format because they were dirt cheap and readily available then. As mentioned, there were a few discs that had remasters that were done well on HDDVD, but aside from that, it had zero advantages.
sawzalot
sawzalot
I have 240 HD DVD movies that I would sell for 2.25 per title but you must buy them all I will not split em up and over 75% of this collection is still sealed in shrink wrap from factory.I will throw in a mint condition toshiba hd-30 player.
Adam
Adam
Do you have a list somewhere? :)
sawzalot
sawzalot
I do but really, to post that would be so painstaking, how bout this I have about one third of the total ever made lol.
I will look to post a list here and in the classified area sometime soon but not tonight.
NoDakNomad
NoDakNomad
I personally prefer Betamax.
