I am trying to decide if I need to go with an HTIAB or a 2.1 setup.
You should listen to these guys.
For years before there was such a thing as Home Theatre, I had a receiver and speakers, with stuff like a phono/8-track/reel-to-reel/casette hooked up to it.
When I decided to go into Home Theatre, I didn't know anything about it, so figured a one-stop-shop HTIB would be a good answer. I got one. Started reading a bit, and a year later replaced it with another one. Continued reading, and soon replaced that one with a receiver and speakers separately. Have been adding components and upgrading separates until today. Now I'm done.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Finally have exactly what I want.
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And it was put together one piece at a time with each component from a different company based on my needs and budget.
My point is, if you get a HTIB and continue reading/studying about audio, or go to friends homes that do, you will likely start replacing components separately anyway. So you might as well START by identifying separate components that match your demands and budget. Save some money. You won't start with top-of-the-line stuff, but you also won't start w/ everything just because it's all from the same company rather than because each component matches your needs/budget.
