First off, I am pretty new to higher-end audio equipment so have some very basic questions, as you will read:
1) I recently bought a denon 3806 and a denon-2910 DVD/CD player to sit alongside (with optical cord hook up between them) . An audio guy from Good Guys set it all up and sounds great. So now I have a new 60 gig ipod and want to plug in the back of the 3806 receiver (which looks like a NASA instrument panel to me) and can't get it to come thru except for the 'phono audio' in (red & white plug in) but sounds crappy and muffled - amazingly the instruction manual seems to give no guidance to where I need to plug in such a device - so which is the best port? (pls remember that I am a novice so detailed instructions are most appreciated!)
2) the ipod came with a red, white and yellow plug in cable so should I use it or is their something better to use that will work with my question above
3) the stereo guy that hooked up my system said if I get an Ipod I 'have to get a stereo docking station' it came with a small charging/docking station so is this sufficient or should I spend around $100 to upgrade that might have a better cable and plug into the 3806 optimally - if you can suggest something specific, pls let me know and is much appreciated!
thanks all!
