Here is a PDF they sent me. 100w into all channels! wow, thats impressive.
well the PDF they sent was toob ig so i converted it to text:
DCOM GFR-700 Multichannel Home Theater Receiver
Preliminary Specifications, Features and Functionality
The GFR-700 will be ADCOM’s first receiver. It will be positioned as a less
expensive alternative to ADCOM’s separates electronics. The target market for
this product is the custom installer/integrator with a product void between ~$1000
receivers and step-up premium separates. It has been designed to be easy to
use by the end customer but offer flexibility on its configuration for the
installer/integrator.
Front Panel
Power Button – ON/Standby, with ADCOM standard RED/AMBER dual LED
Volume Knob – Same as on GTP-880, (-80dB to +10dB)
Source Selection – Tactile switches, VID1 – VID4, CD, EXT 7.1, with LED’s
to show current selection. Has TAPE MON selection for current source.
Room 2 (2nd zone) ON/OFF and SET-UP button with LED (Use RM2 power
button to step through RM2 OSD and VOL to change settings)
Tuner Control – Tune,/Preset toggle, AM/FM toggle, Tune UP, Tune DOWN
Surround Mode – SUR MODE button steps through selections allowed by
DSP mode/input source
Display – 2 x 20 character FL (Same as GTP-860II)
Control – IR Receiver
Rear Panel
Component Video – 4 IN, 1 OUT (follows selection of VID1 thru VID4). Direct
(switched) feed through or video Transcode w/OSD.
HDMI – 2 IN, 1 OUT (follows selection of VID1 to VID2). Direct (switched)
feed through only.
Composite Video – 4 IN, 2 OUT (Monitor-Direct (switched) feed through or
video Transcode w/OSD & Tape – Direct (switched) feed through per
selected input.
S-Video – 4 IN, 2 OUT (Monitor-Direct (switched) feed through or video
Transcode w/OSD & Tape – Direct (switched) feed through per selected
input.
Digital Audio – 6 IN (3 coax, 3 optical) assignable (programmed) per source
selection VID1 through VID4 and CD.
Analog Audio – 1 EXT 7.1 IN, 6 Stereo IN (VID1 through VID4, CD, Tape) 1
Stereo Tape OUT, 2 RM2 OUT (one fixed, one variable), 7.1 Main preamp
out. Room 2 fixed or variable 2-channel out.
Control – 1 12V trigger OUT, 1 IR IN (one set each per Main and Room 2)
1 RS-232 port for custom control interfaces (AMX, Crestron) and ADCOM
firmware updates.
Remote is a UEI based backlit 57-Key Dedicated/Learning type
Amplifier Section
5 channels of 100 ADCOM watts into 8 ohms all channels driven @ rated
THD and Bandwidth.
DSP Modes
ProLogic IIx, Dolby Digital, Dolby EX, DTS, DTS ES Neo:6 decoding
Additional DSP music modes
Triple crossover bass management
RM 2 Advanced Menu through OSD only w/EQ, 2-channel surround, etc.
Warranty
-3 Years P&L
Finish
One SKU, Black/Silver combination
Retail
Introductory MSRP of $1999.00
Delivery October 2005
