Soundmaster89
Hey guys
I have a problem with the MyHarmony software i wanted to change a little setting on my 650 remote but when i try to start the software it gets stuck on the loading screen at 50%. I did reinstall the software but it still doesn't work. I did a google search and i found on the logitech support website the tip to force quit the programm an restarting it but that didn't work either. Anyone with the same problem? any tips?
Note i Didn't use the software for a while (since my last change to the remote sometime in april) so i of course did install the updates when i started the programm and it said there is an update but ever since the last one it just get stuck on the loading screen.
