Harmony remote Mod 900 compatability
jons4aces
I have a small home and don't need much to shake the walls . Ive been reading a lot ,( understanding a little! ) but am going to purchase a Sony STR-Dh540. Does anyone know if it is RF compatible with the Harmony 900 remote? All of my equipment ( components ) are located behind my TV in another room.
Thanks for your time, John
adk highlander
adk highlander
Sith Lord
RF is always proprietary to the company. No universal RF remote will work directly with any component. There will be a base station that is compatible with a remote that will convert the RF signal to IR. The base station will then send the IR signal to the components via flashers stuck to the front of the component.
