Harmon Kardon AVR7300 help
sjp1966
I have had my AVR7300 for a few years now, and all I have really done is set the delays to the speakers. I made it my mission last night to read through the manual and try and understand the features of the unit etc.
The other night I used my digital video essentials DVD in order to try and set up the sound Db levels, but I am having trouble with that disc too, in that I cannot get it to put the pink noises through one speaker while I adjust it and then manually move to the next speaker, but I’ve put that up on another post.
I guess what I am looking for is help with the correct setup for this unit and to help me with the numerous questions I have as I read through the manual as well as maybe helping me with the DVE disc, I do not have a dedicated room, and the room I have is not ideal but I want to get it the best I can in the space I have.
If anyone could help me I would be really appreciative I have tried contacting Harmon Directly but I never ever get a response.
AVRat
AVRat
Most people generally use just the receiver’s test tones to set the channel levels. I also have the 7300 manual downloaded so I may be able help. Check other thread for DVE info.
jcPanny
jcPanny
Receiver setup.
In addition to setting the delay/distances. Look for the following settings:
Speaker levels - usually the receiver will play a test tone while you make adjustments. Ideally, you would use a Radio Shack or other SPL meter to measure the levels.
Crossover - Start with 80 Hz.
Speaker Size - set all speakers to SMALL and sub to ON. If you don't have 7.1 w/ surround backs, set these to OFF.
The DVE disc is most useful for calibrating the video on your display. There should be some tutorial videos included on the disc.
sjp1966
Yes I have a radioshack SPL meter, I will try the test tone on the AMP tonight, I thought the one on the DVE disc would have been better (no idea why i thought that though).
I have a 5.1 set up 4xKEF Q4, Q6c Centre and PSW2500 Sub, I know all speakers are set to small but i will have to find out how to adjust the crossover
thanks for your help, this gives me something to start with.
