Harman Kardon Question?
Skitch
Does Harman Kardon have a receiver out that can do 1080p?
MDS
If the HK you are considering has at least 100 MHz bandwidth for component video switching, it will pass 1080p just fine.
MDS
I don't which HK models, if any, will have HDMI. Regardless, the issue is whether or not the video switching bandwidth is high enough to pass a 1080p signal and if it is at least 100 MHz, it should work fine. The manual for the receiver should specify the video bandwidth.
