Harman/Kardon uses an advanced HCC high current amplifier that actually allows the amp stage to be very linear, by this I mean it has a very impressive 5hZ to 100khz bandwidth, the human ear can usually only hear 20hz to 20khz, but anything above or below will add to the realizm and depth of the music. HK rates their amplifiers at full power across the scale. The hk's will crank up high volumes and still stay clean and also keep their 0.06 or 8 t.h.d. rating across the entire volume allowance. If you are into tech specs, then , they are not the brand for you, but if you're into precise sound reproduction and reliablity then you will be very happy with HK, I say this having owned about 20 receivers over the course of 12 yrs or so, and I finally just couldn't beat the overall sound quality of HK. Mine is just the AVR 110 DTS receiver rated at 45wpc, but this is the most impresive and powerfull sounding 45 watts I have ever heard, and most of my fellow enthusiast friends agree that is sounds like anyone else's 100wpc. Word to the wise: make sure whatever amp you buy says ALL CHANNELS DRIVEN SIMULTANEOUSLY! not 100 x6 @ 1khz. That 1khz is only one frequency in the entire 20hz, 20,000hz range. Hope this info helps.
