Harman Kardon AVR 7300 & DVD Connection
sjp1966
Hi
I Have a Harman Kardon AR 7300. On the back into has a component out connection to connect to the TV and 3 component in’s that you can use to connect devices to the amp to view on the TV. I currently have my Xbox 360 and my DVD connected via this method.
My question is this. The DVD is a Harman Kardon 22 and I used to connect is directly to the TV using a component connection, However the AMP says it connects via Faroudja processing at 480p
I am trying to find out if the connection that is direct to the TV, will give a better picture than that though the AMP?
Steve
