Sangeet
Hi guys,
Any word / advice / comment on Hales Revelation 3 speaker ? I found the sound quality of this speaker amazing. This is available with a firend of mine for sale.
Does any of the latest speakers sound (sound quality and soundstage) as good as or equivalent to Hales Revelation 3 ?
Irvrobinson
Irvrobinson
Here is the Stereophile test report, which includes some measurements. I heard this speaker many years ago, and concur with the reviewer's conclusions - it's a pretty good speaker. The biggest difference between these and newer speakers is that, IMO, the quality of modern tweeters has come a long, long way since the Hales were designed, so while the Hales probably sound good, a lot of more recent speakers will sound better, I think. Assuming you can get these for a very reasonable price, like perhaps $1000 for the pair, they are probably worth it.
agarwalro
agarwalro
IMO, unless you're very sure of the speaker's history, stick with new ones to have full warranty. For instance, a speaker that sat in a storage shed for a few years may not show cosmetic damage, but the driver performance/life expectancy could be compromised.
Which other speaker did you listen to?
Sangeet
Thanks.
1) I'm getting this for $ 850 (without grill cloth)
2) Do you know of any newer speaker that will sound the same or equivalent?
Sangeet
Thanks but you know of a speaker that will sound similar or equivalent ?
I have listen to following speaker :-
I have JBL ES 90
Bowers & Wilkins 800D2GB Diamond Series Speaker
Bowers & Wilkins 803D2R
Polk RTiA9
Polk RTA 12
KLIPSCH RF7 II
Klipsch RF-82 II
Bowers & Wilkins 683.
Dynaudio AUDIENCE82CH
MARTIN LOGAN VANTAGE DC
Dinitive Technology - SuperTower
Energy CF 70
AR
Some infinity
all KEF
and many more in frys and Best buy
agarwalro
agarwalro
Is your budget about $1000? There are several I can recommend...
I have JBL ES 90
Polk RTiA9
Polk RTA 12
KLIPSCH RF7 II
Klipsch RF-82 II
Energy CF 70
AR
Some infinity
all KEF
Awesome! Which ones stood out (positive or negative) and why?
Sangeet
Yes my budget is $600 to $800 but want to be 100% satisfied so $1000 max.
The speakers sound I liked the most was :-
Hales revalation 3
Polk RTA 11t
Both the above are vintage But I want to get something latest that sounds similar.
agarwalro
agarwalro
The Kef Q500 or Q700 is one to demo. Here is a review for the Q900 which is the top of line. As you go down the line, you only loose low end extension since the coaxial mid-tweeter is the same across the line.
They are available on Accessories4Less (open box, cosmetic blemish) for $380 shipped and $500 shipped (each) respectively.
