As i say in every post of mine.."Well,in CAR audio.."
When i first got into car audio,i was told about the bi-amping,but i heard things i knew weren't supposed to sound THAT way..
well,that was years ago,like 16..anyway,the point is this..
i have found that bi-amping doesn't take into account speaker impedance curves,which directly relate to response curves(well close enough anyway..)
not to mention phase shift,which is again accounted for in a passive crossover( a good one!)..these things are far more important on the high side of our beloved octaves,above a sub to sub-mid cross anyway..
now taking into account dsp,and other such wonders,i am guessing most of these things can be accounted for..
but i ran the bi-amped course(i guess technically tri,i still am an advocate of sub to mid,but now i try to stay away from anything bi-amped (again i guess,i think you understand..) above ..say...150-180..
the phase shift at a crossover point,both drivers playing,and if you dont shift right(or left..haha) then your imaging is WAY off.sometimes anyway..
MOST peoples general perception is usually being impressed,with the fidelity,but close your eyes,picture the scene(i guess i say that alot too..) listen for how well placed that piano is,or especially a female voice,i forget what freqs,but i think around 2000-4000,if the crossover is around there,and your phase shift is off,you can move a couple inches left(or right..seriously this time!) and the voice can 'move' a few feet! or just be all over the place,so to speak,i think you understand..
alot (hell,ALL)of the high end systems i have done,i listen to Madonna's immaculate collection..not to say this is the best of anything,except that i KNOW what it sounds like..i have heard it on systems(car now) that ranged from 5,000,to one that was worth over 200,000..
i just know what the spit sounds like when it separates from her teeth,
i listen to one particular track,i think 15( i haven't done what i would consider a high end system in like 4-5 years)
people just want boom...
off the subject..there are advantages to passive's,i would spend the money on a bigger amp,and use the passives..
we ALL know what a larger amp does for sound!
just one persons opinion..
thanks for listening..try closing your eyes next time,and listen to something you think you know..
